audi recall
Old 12-04-2007 | 09:45 PM
hellperados's Avatar
Default audi recall
hi
I just bought 2 month ago a 1997 a4 2.8 quattro. I'm wondering if all the recall has benn done on this car. How can I check that? Should I go to a dealer?
Also , the cruise control and the interior door lock are not working. Any ideas of what could it be?
Thank
Remi
Old 12-04-2007 | 10:09 PM
Deanne's Avatar
Default RE: audi recall
you can call an Audi dealer and give them your VIN #....they can check for recalls and confirm if they have been done on your car.As far as the two other problems...sorry can't help you there.
Old 12-05-2007 | 12:06 PM
99A6Q's Avatar
Another way to check for recalls is carfax. If you run a carfax on a car and there are pending recalls that have not been done yet carfax USUALLY will let you know.
As far as the other things. Could be a number of things, try checking some fuses first.
Old 12-05-2007 | 08:01 PM
I'll call a dealer tomorrow.
For my cruise control , I check all the fuses and they're all ok but the onwer manuel said that the cruise control fuse is at position 11. If i look at the position 11 in the fuse box it's a spare , there is nothing connected at this place.
Old 12-06-2007 | 02:22 PM
AZAudiA6Q's Avatar
From what I've read around these forums, these problems usually come down to a bad relay or switch somewhere. Try seeing if you can trace the problem back to its origin, otherwise it looks like you'll need some dealer help.
ORIGINAL: hellperados
hi
Thank
Remi
Maliza Bayb
01-20-2013 01:34 PM
99A4NOW
08-19-2010 10:49 AM
acetrebo
10-17-2007 03:10 PM
ironman
08-21-2007 04:37 PM
