AirBag Light??
RE: AirBag Light??
if you don't have a card from the dealer with a 4 digit code then you have a problem and it will cost you at the dealers, im sorry to be sceptical but too many people think there is an easy fix and there isn't
RE: AirBag Light??
Well, I do have all my original paper work so I will go and check for it. So I'm assuming I'm going to have to reset my radio once I pull the ground off my battery? So this is my plan, check the yellow connections under my seat. Then while the car is off, pull the ground off my battery for a few mintues, reconnect it. Then wait and see if my Airbag light comes back. Then I guess, reset my radio using this 4 digit code. Am I right in these proceedures or not? I do appreciate your help! At 73,000 my 98 A4 is starting to have multiple electrical problems.
