Aftermarket Radio Install
Hello,
I need some help to install and aftermarket radio in my '93 100Q. The orignal radio is a Gamma, and has 3 seperate plugs in the back. From what I understand my car has powered Bose speakers, and this makes the operation more complicated.
Is there someone who may know how to proceed with the aftermarket radio install?
Thanks
Thanks
RE: Aftermarket Radio Install
I recently installed an aftermarket deck in my a4 it was a lot easier than you might think...i needed three things
1)A Wiring harness, this basically connects toyour factoryplug/s(power and speakers)i found one on ebay for your car http://cgi.ebay.com/1989-1995-Audi-1...em190088679922
If anything this is the hardest thing to install just color match the wires from the wiring harness with the ones from the deck
2) an antenna adapter, makes it possible to connect your factory antenna to the deck
3) a dash kit, i needed one on my car because the stock delta radio was bigger than the usual standard size aftermarket decks
And thats about it you can also try http://www.scosche.com/these parts
