ABS brakes activating at slow speeds
hey guys, i just picked up my first audi about a week ago and just recently i've been noticing the ABS breaks are being activated at very slow speeds like when I'm parking and stuff. it doesn't do it all the time, but can anyone help me with this?
RE: ABS brakes activating at slow speeds
Sounds like you have a dirty ABS sensor. Had a similar problem after having an axel replaced.
You will need to pull each wheel off, the abs sensor is a plug that goes into the hub, they sort of pull out. I sprayed a rag with wd-40 cleaned off the sensor and the hole and have not had the problem again.
