A6 c6 4.2 coolant in oil????
Old 03-08-2017 | 04:38 PM
jdyer's Avatar
Originally Posted by hlarson
Only things I've noticed is there is a slight sputter at times....can only notice if you're parked and behind the tailpipes. The you can feel it. Also, the coolant definately disappears faster in the winter.
So I've got a '07 A6 also with the 4.2 and it's just started with coolant in the oil cap, but there's no chocolate milk on the dipstick yet. I'm wondering if the oil cooler fix stopped the contamination of the oil? You say you've gone another 40k miles, so I assume they're not mixing, you only have disappearing coolant. Did you ever have coolant in the oil?
Old 04-21-2017 | 12:06 AM
a4a4a6's Avatar
Hi,
just read your post. I did have similar issues with coolant mixing with oil. First thing I did was to analyze the oil. Take the sample from the engine to be tested for presence of coolant. You will get confirmation if it is an internal leak and they find coolant in the oil. I had to redo pretty much everything related to the coolant lines. Mine was internal leak and the coolant was entering the engine through the back coolant pipes (on the back of the engine where the timing chain is).
GLD
12-06-2008 05:22 PM
Ph3N0m
10-21-2008 12:58 PM
less_of_me
05-02-2007 03:29 AM
Quick Reply: A6 c6 4.2 coolant in oil????
