A4 wont start after refueling (with vag codes)
Old 03-18-2008 | 01:28 AM
neidermayer's Avatar
Default A4 wont start after refueling (with vag codes)
so after i fill my 99 a4 quattro with gas it wont start properly. i turn the key, the engine revs and turns but doesnt catch. or it will catch but immediately stall. after 15-30 minutes it will start. usually the engine turns for awhile, i leave the key forward, and it eventually catches.
so i vag it and get these codes:
16544 oxygen (lambda) sensor b2 s2: no activity
p0160-5-10 intermittent
17544 fuel trim: bank 1 (add): system too lean
p1136-35-00
17546 fuel trim: bank 2 (add): system too lean
p1138-35-00
16839 evap system:large leak detected
p0455-35-00
Old 03-18-2008 | 04:14 AM
PRican1.8T's Avatar
Default RE: A4 wont start after refueling (with vag codes)
i just read the recalls and TSBs and i think there's a recall for the A4 with a fuel problem. not sure, might wanna double check it
Old 03-18-2008 | 04:18 AM
PRican1.8T's Avatar
just double checekd it. there's nothing for your car. that was just on my car
Old 03-18-2008 | 09:58 AM
CRAZYHAWK's Avatar
Clear the codes and see if they return.
P0455 could be caused by a loose or faultygas cap.
You might have a vacuum leak, causing the lean codes.
Old 03-18-2008 | 01:59 PM
these tsbs seem similar.
https://www.audiforums.com/recalls-a...150101/TSB.htm
https://www.audiforums.com/recalls-a...150102/TSB.htm
mechanic says its likely a solenoid isnt properly firing so the engine is flooding.
apr_a4
09-01-2011 10:00 PM
Huntersirg
05-07-2011 11:31 PM
socaljoe
B7 Models
12-30-2010 10:36 PM
LRpgulf77
02-06-2010 09:45 PM
mack29730
05-15-2007 09:21 PM
