A4 2004 1.8T Code P0012
Old 12-15-2011 | 01:44 PM
supradibbs's Avatar
Default A4 2004 1.8T Code P0012
Hey guys.
Ok so i have had a nightmare with my 04 1.8T A4, i took the car in to have the emissions done for my tags and it failed for the engine chek light not working and the following codes.
P0012
P0420: Cat or O2 sensor are my thoughts.
Now the P0012 seems to point towards the cam chain tensioner.
I want to have this replaced my self so after any top tips or a how to guide, or is this something i really should not attempt i.e any special tools required?
Also i looked on ebay and seems i can get the required parts including new timing chain alot cheaper than OEM.
Should i steer well away from these, can someone recommend where to get one from that they know what end up with me having to do a top end rebuild.
Thanks in advance time is really against me as i have to get my tags by the 29th of December.
Old 12-15-2011 | 01:45 PM
supradibbs's Avatar
Just to add, my engine check light is now working after i removed the black tape from the light assy that the previous owner did to mask the problem!!!!
Old 12-15-2011 | 08:21 PM
supradibbs's Avatar
Anybody???
Old 12-23-2011 | 01:01 AM
EuroCustoms's Avatar
Former Sponsor
Here is a DIY on replacing it if it is bad. It's for a passat but the procedure is essentially the same Camtensioner Replacement
reaper1976
03-21-2014 02:04 AM
Subarashī Kao
08-18-2012 06:18 PM
patty36j
10-17-2011 05:08 PM
AudiCross
10-16-2009 06:41 PM
willk824
09-30-2007 07:05 PM
