98 A4 Quattro tail light assembly help
Ok, so I've had this problem with my right rear tail light (more exactly the brake light) not working some of the time. I would correct this more often than not just by disconnecting and reconnecting a new light bulb. It would last a day then burn out. I got fed up with doing this and found the parts in the bulb tray itself were missing. I was wondering if anyone out there knew where I would be able to found the bulb tray/housing (not the exterior cover).
We'd need your vin # to determine which part number you'd need for that RR bulb holder. It is 46.50 for either p/n and 3 days away to order in to us first. Plus about 8-11 dollars UPS ground shipping out to you. This is for a sedan, not avant. Thanks, Jeff.
