2012 a3 tdi disabled!!
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
Hi,
2012 A3 TDI 67k miles, had a melted fuse holder at the engine bay- fuses F16,17 melted into the holder. After looking up this issue online I found that similar instances where other Audi owners needed this part replaced with newer part 1K0937125D. So I replaced it with the newer part. After replacing this, when I turn the ignition to the on position all the warning lights come on, sirens wail, and the dash settles with TPMS, and Stabiliser malfunction errors. When i tried to start the car it just cranks, but will not fire up, and now the key will not come out without disconnecting the battery, and the gearshift will not shift into Neutral.
I've checked all the fuses, and they all check out good. I tried connecting a scanner and there is no power to the port. I've tried touching the leads of the battery cables together to reset. Has anyone run into this? Any help would be great.
Thanks,
Al
Thanks,
Al
