2002 A4 with electrical problems
RE: 2002 A4 with electrical problems
Feel your carpet on the driver's side and see if its wet, if it is the comfort control module might have gotten wet from a leak into the car. In which case you have to pull the carpet up and replace the module, then remove the battery and blow out the pleanum drain so it doesn't let water back into the vehicle.
