2002 2.4 A6 Multitronic problem..PLEASE HELP!!!
Hi,
I have a 2002 A6 2.4 Multitronic. Millage - 325K
Problem: Gear engages fine when car is cold and can drive for about 1km without any issues. All lights on dash light up PND1234 and car completely goes into limp mode (Neutral) Will not engage gears again after that.
Things done to try and sort the problem: Diagnostics run - NO FAULT CODES.
Had the oil and filter changed (Old oil was terrible) The oils was changed and run through the system drained and fresh oil put in again) Car was fine for about 80km and then the old problem resumed.
Please help, I have no idea what to do now. P.S. ECU also no faults on diagnostic.
Thank you
Thank you
