2001 A4 1.8t engine problems help!
Old 06-08-2010 | 12:39 AM
kpadlina's Avatar
Default 2001 A4 1.8t engine problems help!
Doing a compression test all the cylinders were good except 2nd one back while cranking has 158psi then drops to 0 then back to 158 etc. Think a bent valve is the problem? I'm getting 2 knock codes and camshaft position sensor advanced...
Old 06-08-2010 | 03:13 PM
R.A.I. Motorsport's Avatar
Former Sponsor
Have you checked the physical timing? The camshaft position sensor is usually the indication of it being off.
Old 06-09-2010 | 11:53 AM
kpadlina's Avatar
I haven't actually checked cause I can't see any timing marks on the cam or crank shaft but the belt is tight and looks to be in decent shape... also why would only #2 cyl be the only bad one?
Shawn Miller
03-12-2013 08:17 PM
bpost
09-22-2011 11:36 PM
AudiinNorway
11-23-2010 05:01 PM
audipower
03-31-2009 01:49 AM
dufferdude
11-13-2004 11:58 AM
