01 A6 Brake Squeal
01 A6 Brake Squeal
Incredibly painful brake squeal from frt brakes at 10 mph or less. 2 new rotors, 3 sets of pads, two dealers and a tire store later, no one can figure it out. Recentlly replaced front tie rod ends and CV boots, alignment and tire balance. Any help is gratefuly appreciated. 2.7T, auto-stick 71k miles.
RE: 01 A6 Brake Squeal
swing by your local auto parts store and pick up some brake lube.
pull teh wheel
pop out the pad
swipe a finger (-ish) of lube on the back of each pad
re-install the pad
re-install teh wheel
drive
come back here to tell us if THAT fixed your noise problem
pull teh wheel
pop out the pad
re-install the pad
drive
My experience with brake squeal is due mainly with CHEAP brake pads!
There are expensive, mediocre and CHEAP brake pads available on the market. Choose CHEAP and you will have squeal!
