Best way to hardwire Valentine 1?
Old 03-31-2006 | 08:06 PM
a4crazy's Avatar
Default Best way to hardwire Valentine 1?
Anyone have any expiernce with hardwiring their V1's to their a4s?
Old 03-31-2006 | 08:25 PM
kpatz's Avatar
Default RE: Best way to hardwire Valentine 1?
I'd like to know too. I hardwired mine into my Saturn (tapped into radio circuit) but just got a 2002 A4 and want to transfer it there.
Some other threads mention wiring it into the sunroof or homelink power in the headliner, and others say to run the wire down the A pillar down to the fuse box. One question I have is, is it possible to run a wire down the A pillar if the car has side curtain air bags?
The reason I ask is because I have the V1 concealed display and want to mount it low, so I have to get a wire down there since I'll have my V1 on the visor.
Old 04-01-2006 | 01:02 AM
lbraasch's Avatar
I read an article online about someone's install. I know there is a tutorial out there someone. As long as you don't have the avant, you can get the power "hot" wire from the rear wiper fuse spot, and then just ground on one of the surrounding bolts. As for running the wires, you gotta just get creative and stuff it up along the headliner/windsheild area.
Old 04-01-2006 | 03:33 AM
ckandes1's Avatar
ORIGINAL: kpatz
don't screw around with wires near the side-curtain airbags, you're right to think not to. They airbags could very easily snag on the wires, not coming down correctly.
Old 04-02-2006 | 03:28 AM
pootey's Avatar
http://www.audiworld.com/tech/elec32.shtml
http://www.audiworld.com/tech/elec105.shtml
see if that helps you at all.
Old 04-03-2006 | 01:01 AM
eblok321's Avatar
i just took apart my interior lighting and sunroof control unit, and hardwired it right into there. it ended up being real easy.
Old 04-03-2006 | 02:44 AM
DJ_JonnyV's Avatar
I'm about to do the same for my Valentine 1. Care to share which color wire and what year your A6 is? I'm going to try a cut-in adapter I ordered straight from Valentine 1 along with making a custom lenght RJ11. Thanks.
easeupjosh
04-28-2013 01:25 PM
08_blau_avant
B7 Models
09-03-2008 11:54 PM
KarlMarx
01-06-2007 05:11 PM
dbc632
12-22-2005 02:31 PM
DaGimp
01-15-2005 07:42 PM
