A6 Mirror Switch pigtail?
Does anyone know where I might find a pigtail connector for an A6 power mirror switch? The dealer says he has the connector, but I would have to install the wires(???). Part number is 4B1959551.
Thanks in advance.
Thanks in advance.
That part number is incomplete, should be 4B1959551 B98, the B98 is a color code. But that is the trim for the surround for the mirror switch in the center console, it's not for the connector to the bottom of the switch. You must have some burnt wires that attach to the mirror switch? If so I can help you but I'd need to know what year your car is, need the vin number in case you have seat memory etc that may need a different connector housing. Then I can find the wires and or terminals that connect to the switch.
ima_slap_joO
05-31-2008 10:55 PM
ImTheDevil
11-13-2006 05:50 PM
