Audi Day , S4 & S5 detail
2010 Red S5 with special dealer package: swirls, waterspots , some haze …neglected.
Before pictures:
I did one step meguiar`s 105 on orange pad with DA and 1 step meguiar`s 205 with DA. Optiseal was use for protection and souveran wax on top.
Before/after on door panel:
All this are afters:
Before pictures:
Bear hit this S4 somewhere in north before the car got in texas. The car had severe swirls , deep scratches all over. The clarity was restore to 100% and the swirls a good 80% improvement, the car still has scratches , has been to deep to deal with them.
Some pictures before :
A test spot was done and the winner was 2 passes with yellow cutting pad and meguiar`s 105 on Flex DA and 1 pass with meguiar`s 205 and polish pad on PC. Optiseal was use for protection.
Another before/after:
Some of the scratches was light wetsand
Afters:
Afters:
help!!
Hey first of all Thanks for all this help you gave us about keeping our Audis Shiny!!!
But i have to tell you that i dont know nothing about waxing and things related to it, would you give me a brief explanation on how to choose, use this product and what kind should i use and the colored pads!!!
My car have many of those water spot problems which i hate so much!!
i will go with a portal cable , or any DA , like meguiar`s g110 , or g110v2 , or g100.
a polish pad , ( white from lake county , or yellow from meguiar`s)
use a final polish meguiar`s 205 is a good product.
set the DA at speed 6 , you work 2ftx2ft , up/down , left/right ,
the first 2-3 passes you put some pressure on machine after that just light pressure. do 6-7 passes.
remove the polish by wipe with a clean microfiber , wipe with alchool to make sure you remove the polish oils, and inspect your work.
if the defects are not severe , a final polish should take care of them.
good luck
good luck
smokn944
09-27-2009 07:00 PM
