Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
2001 a4 help
Old 04-17-2012 | 05:17 PM
KarlD.'s Avatar
Default 2001 a4 help
I have 2.8 quattro. I put 20 bux of gas into the car and had a 3/4 full tank. I drive maybe 5 total miles and the needle drops to a little over half. But when i turn the car off and use it later on in the day, the needle will go back up again SOMETIMES. I know the car is a v6 but...
Old 04-18-2012 | 07:25 AM
jmarshall098's Avatar
Did you checked the battery level? It could be possible that the fuel meter won't be getting enough current supply to read the values correctly.
Old 04-18-2012 | 11:55 PM
ImTheDevil's Avatar
It's the sending unit in the tank. Either the resistive element needs cleaning or the small wire on the float arm broke and needs repair. Simple fix.
Old 04-19-2012 | 10:30 PM
KarlD.'s Avatar
Thank you for your contributions. My battery is producing adequate charge so i think it is the sending unit.
Wtftylor
11-01-2012 01:01 PM
klipsch21
07-27-2010 08:41 PM
Euthanasia
02-22-2008 01:30 PM
Jorgen
07-29-2006 02:25 PM
Bit646
05-11-2006 05:24 AM
Quick Reply: 2001 a4 help
