taking out and putting in a new radiator in the coupe
My new radiator came with the new hoses i ordered (damn post office sat something heavy on top of the rad, so the big hose connecting points on the tanks got squashed in a bit)... i also ordered the little rubber mounting things.. so .. what do i have to take out to get the radiator and fan housing out??? I know there is a bracket in the front.. but when looking around i cant any of those little mountings. Do i have to take the expansion tank our or anything like that???
also what size is the fan switch that goes into the tank at the bottom?? 22mm??
RE: taking out and putting in a new radiator in the coupe
basically its take out and put in procidure. so by looking on your new rad you can find where exavtly the mounting points are.
I would think that you will need to move the fans out the way. the rad should be able to come out easy or with a little strigle. just make sure you have enough space.
alrighty sounds good enough. From what i read i need to take the rad + the fan shroud all out at once.. and reinstall that way (easier i guess?). While all that is out.. im going to put in the new thermostat.. i will be sooo happy when i can drive the car again. I emailed the company that i ordered the rad from.. so if there are any cracks..i can send it back and get another one. damn post office.. i hope our new tv isnt all smashed up when it gets here
thanks for your help!
nick17
07-30-2009 08:26 PM
neomaxddr
03-28-2009 07:16 PM
cvacc411
01-29-2009 04:58 PM
