Synthetic oils in a 1984 5000s
Old 11-14-2005 | 07:13 PM
xmishx's Avatar
Default Synthetic oils in a 1984 5000s
I just put in some synthetic oil, and a fresh filter in a recently acquired 5000S. Though the car was running fine before the change, now I'm getting a oil warning lite and temp warning lite. I have plenty of oil in the car and the temp gauge in the car reads acceptable. Any clues? Help!
Thanks,
X
Old 11-14-2005 | 09:11 PM
0fframp's Avatar
Default RE: Synthetic oils in a 1984 5000s
Any clues? Yeah, probably the bearings or the oil pump is shot. Hook up a cheap mechanical gauge just to make sure that it is not the pressure sensor. I think that the previous owner put in 20W50 or some additive (like motor honey) to build up oil pressure and quiet down noisy bearings. When you drained the oil you replaced it with a thinner synthetic which is easier to pump and lowers the pressure. There is also a pressure regulator mounted on the pump and is easy to access, maybe the spring broke or weakened.
Old 11-14-2005 | 10:46 PM
kakarot's Avatar
unscrew filter put a can under it crank the engine to get oil out and put higher grade oil in their. find 25W-60 or 25W-50. or put addictive to increase the oil grade, or just change it again for higher grade. do that if in the morning when you start the car the light is not on for oil pressure.
else you have a bad spring, or and pump.
joesaudi1
06-29-2015 11:51 PM
Phaedrus44
09-06-2007 10:54 PM
audi5000S85
02-14-2007 08:53 PM
TuckerGgener
01-05-2007 09:34 PM
Phaedrus44
12-06-2006 04:46 PM
Quick Reply: Synthetic oils in a 1984 5000s
