New buyer dilemma 1990, 1993, 1995
Old 09-20-2006 | 09:58 AM
bostn33's Avatar
Default New buyer dilemma 1990, 1993, 1995
First time post and former Audi owner (well, a 1984 Quantum is about the same thing!) is looking to step back into the ring and pick up another Audi. It has been a while, but as I searched around I narrowed it to a few options -- 1993 90 CSQ (~$1800, 140k), 1995 90 CSQ (~$3k, 170k) (I believe they're both 'sport') or the darkhorse 1990 20V Q ($cheap, 165k) 4-door. All cars need a timing belt all cars are in the snowbelt.
1993 - bad paint, timing belt needed, rear window motor broken, functioning AC, no leaks, brakes ok, rear muffler going, tires ok, rear shocks (struts?) a little springy
1995 - timing belt needed, rear window motor broken, AC broken, minor hood damage, tires ok, suspension ok, brakes ok, muffler going, no leaks
1990 - timing belt needed, wheel bearing, you guessed it..rear window motor toast, unknown AC issue
I've test driven the '93 and '95 but haven't looked at the '90 yet (it's far away). They both felt pretty solid and strong. In the end, I assume the cost of the 1993 vs 1995 are about the same given the immediate repairs that are necessary. Would there be any other issue that would sway someone to pick one over the other? I'm nostalgic for the 20v because, well, the Quantum was a 5cyl and it had decent power and was easy to work on. I'm not sure whether it's the same for the 20v.
Old 09-20-2006 | 05:06 PM
InExile's Avatar
Default RE: New buyer dilemma 1990, 1993, 1995
go for the 20v ... less rust if nothing else and timing belt change is easy
Old 09-20-2006 | 05:10 PM
techbod's Avatar
yep I agree the 5 cylinder 20v 1990 was a favourite of mine because of its smooth but brutal take off at lights plus it doesn't have all the new slow me down crap on it like EGR/CAT and computers all over the place
Old 09-20-2006 | 06:44 PM
kakarot's Avatar
its hard to choose, I would get 1995, couse its more newer, so like if 90' has less problems, I would go with it. and swap the hood later on, for B4 looks.
jg329
11-26-2013 10:59 PM
Brautty
12-13-2011 09:28 AM
199590csq
03-29-2008 02:38 AM
Audi_Skydiver
10-23-2007 03:26 AM
NWBOB
03-02-2007 11:15 PM
Quick Reply: New buyer dilemma 1990, 1993, 1995
