help???
help???
ok,we just got apearl white1987 Audi 5000CS Turbo Quattro with a 5 speedfor $1,900andwe need help finding cheap performance parts for it. We recently painted the brake calipers red and currently it needs a license plate bracket for the front. We plan on buying a new shift **** and pedal set for it. The roof needs a repaint because it sat under a tree and has sap spots. If anyone has any ideas as to what we can do to improve the performance at all, please let us know. Thanks!
-Wrong Turn & Big Bear Houghtalen
RE: help???
First thing to do with this car is to drop a performance chip into it and put a better wastegate spring in. I did this with my 5000 and the increase in power is great. It pulls very strong through 3-8k. Be careful though as you may have to shim the wastegate spring to prevent overboosting which will hit the fuel cutoff and isn't good for the motor. This simple add-on does a lot for that car.
