ECU replacement
Old 04-19-2006 | 01:30 AM
ryin1984's Avatar
Default ECU replacement
I just got an 88' A1000 and the ECU is fired, since they no longer make the computer for my car, can I take a a ECU from any other model and wire it into my car?
Thanks
Old 04-19-2006 | 01:36 PM
kakarot's Avatar
Default RE: ECU replacement
easier get a Stand alone ECU and plug it in.
you steal need to rewire the system.
or Junk yard.
Old 04-21-2006 | 10:11 PM
0fframp's Avatar
Check the Bosch numbers on the ECU, if they match you can swap. Don't mix between automatic and manual transmission ECUs if the numbers don’t match even if the model years are the same.
mokey40
B7 Models
11-28-2014 12:42 PM
mtnxtreme
Audi Q7
12-16-2013 01:11 PM
matthayzon89
07-31-2013 10:51 PM
hankeester
06-24-2009 12:10 PM
Quick Reply: ECU replacement
