dead S4
Old 03-22-2008 | 10:18 PM
94S4's Avatar
Default dead S4
Well we had about 8 inches of rain about 4 days ago and guess what the drain under the cowl panel was plugged up. vacuumed about 2 gallons of water from the floorboards and now that the car is dry the car wontrun.It did run but the check engine light was on.now the check engine light wont light when cranking and the car wont start. the other thing that wont work is the inside lock switch(wierd).Any help would be appreciated
Thanks
Dave
Old 03-28-2008 | 10:59 AM
viper771's Avatar
Default RE: dead S4
where is the drain under the cowl panel located? I have water every time it rains on the pass. side floorboard. I feel your pain As for it not starting, I am not sure. Did you check all your fuses? I think I burnt a few relays/fuses out when I had heavy condensation inside the car.
Old 03-28-2008 | 12:32 PM
street2gen's Avatar
Member
Default RE: dead S4
ECU get covered in water or was it not that high?
Old 03-28-2008 | 12:41 PM
NH_USA's Avatar
Default RE: dead S4
OK -- guys make sure the cowl and roof drains are clear.
94s4 - it might be dry on the surface but I'd bet it is still wet under the carpet where the wires are.
thorjov
11-04-2015 09:19 PM
sujoyron
10-04-2014 01:56 PM
tom.beckman
09-02-2013 10:19 AM
wdiaz300
05-14-2008 08:10 PM
proulx00
07-05-2007 11:11 AM
Quick Reply: dead S4
