Clutch problem?
Old 09-24-2005 | 01:55 PM
douggywolcott's Avatar
Default Clutch problem?
Basically if I even touch the clutch, i get this grinding noise. So therefore i can't shift. Any Ideas as to what it is? Would I need a new clutch?
Old 09-25-2005 | 10:10 PM
0fframp's Avatar
Default RE: Clutch problem?
Sounds like the throw out bearing. You have to drop the trans.
Old 09-26-2005 | 03:45 AM
gmatov's Avatar
Why can't you shift?
Bad throwout bearing will grind or chirp or make any kind of noise, and indicate you have to change it, but it will still, until it grinds the fingers off, declutch the vehicle.
At least will save you the towing fee, even if you have to start the car in gear to get it to the garage.
Cheers,
George
BTW, 200, or less, DIY, 1500 Audi Dealer, guaranteed. Not easy for a beginner, but not super hard, either.
Old 09-26-2005 | 03:54 AM
I haven't tried to shift. I heard the noise and i stopped the car. If it is the throw out bearing, how hard is that to change? I' about to junk the car. should i just get under and drop the tranny if i'm going to junk it anyway?
Old 09-26-2005 | 04:02 AM
gmatov's Avatar
If you're gonna junk it, go ahead.
If you still wanna drive it, no real biggie, you just have to have some mechanical knowhow. They ain't easy to work on, but they are not real hard, either.
I've done them, if you work with your hands in your job, you should be able to do it, if you work at a desk, mebbe not.
Cheers,
George
ikkezelf
01-31-2008 06:54 AM
beetee
06-01-2007 06:18 AM
Matt_Iliketurbopull
05-01-2007 05:28 PM
Matt_Iliketurbopull
04-28-2007 03:06 PM
dane
03-03-2005 07:25 PM
Quick Reply: Clutch problem?
