Audi 89 coupe electrical nightmare
Old 12-07-2005 | 02:50 PM
viper771's Avatar
Default Audi 89 coupe electrical nightmare
Well I had time to get it into the garage tonight so i can take a closer look... something on the left hand side electrical is screwed up.. i have been looking into the bentley. I will update more tomorrow.. but i had a quick question on the heated mirrors.. The 2 loose wires on each side are a black and a yellow wire. According to the bentley manual.. the hook somewhere.. do they hook to the rear of the mechanism or to each other. or what?? Any ideas?
Old 12-08-2005 | 01:42 AM
kakarot's Avatar
Default RE: Audi 89 coupe electrical nightmare
they are plus and minus, when go through the mirror's heating element it heats up, and unfreeses mirrors.
mirrors them self have to have connectors, to be connected. if so, cheack ressistence between poles on mirror, if its not infinite or 1 then you can probably connect with no problem. also turn the heating of glass on and check voltage at the connectors,should be: black is ground, yeallow plus. around 6V-14V depends on setup germans did. hope it helps.
Old 12-08-2005 | 09:46 AM
viper771's Avatar
Thanks for the info.. the glass itself has no connections on it.. except for plastic.. see i took these off another car. I did order some orig glass off a guy back in the states, but 2 packages i ordered (one was new gear oil) have not arrived, and its been a month now ;( I will look into the wiring more today
Old 12-08-2005 | 10:15 AM
kakarot's Avatar
welcome
go to http://www.autolib.diakom.ru/CARS2/index.html you might probably require russian to english translator.
go to http://www.rambler.ru/dict/scripts/g...art=0&count=15
just put a word in and press "HAUTU"
leonoragrant
Dealerships
09-25-2014 06:00 PM
Rich Live
10-20-2009 02:16 PM
vaportrails
04-14-2008 10:51 PM
305audi
05-23-2006 06:48 PM
morter
05-04-2006 01:04 PM
Quick Reply: Audi 89 coupe electrical nightmare
