94 cabriolet with temperature light on
Old 10-17-2010 | 12:09 PM
westerville's Avatar
Default 94 cabriolet with temperature light on
The temperature light keeps coming on but the car is not overheating. Had the radiator flushed and filled but light keeps coming on. Could it be the water pump going bad? I found some anti-freeze on the driveway so now I think it's the water pump.
Thanks
it turned out to be just some clamps loose and letting the fluid out, so that did not cost anything!
Thanks
Old 10-30-2010 | 11:04 AM
bluecab98's Avatar
Yes it could very well be the water pump. I have a 98 and replaced it myself. Kind of complicated because you have to take out many parts to get to it but saved about $1200 in parts/labor because I replace the timing belt also. If you plan on DIY I can give you tips, if not be prepared to shell out around $1500 because its a good idea to have the timing belt replaced at the same time.
Isramirez21
12-17-2008 11:15 PM
audikiller09
10-28-2008 10:25 PM
mypreludeisred
03-13-2008 12:16 PM
scerman1gg
10-26-2006 05:17 PM
dragondesigns
08-10-2006 07:38 PM
Quick Reply: 94 cabriolet with temperature light on
