90s over-heating, & replacing thermostat?
Old 07-25-2007 | 01:35 AM
TJ66's Avatar
Default 90s over-heating, & replacing thermostat?
90s over-heating, & replacing thermostat? [hr] I’ve been experiencing an over-heating problem with my 1993- 90s, the cooling fan isn’t coming on. I recently replaced the cooling fan relays, & still it doesn’t come on. Also, recently I replace the coolant expansion tank because it was leaking. Now I believe to remedy the issue, the thermostat needs to be replaced. Can anyone tell me where exactly is it located, & how “easy” of a job is it to replace?
Also would you recommend replacing the fan switch at the same time?
Thank you in advance [/align]
Old 07-27-2007 | 06:19 PM
InExile's Avatar
Default RE: 90s over-heating, & replacing thermostat?
thermostat is easy ... look for it at the end of the lower radiator hose .... you might need a radiator fan swtich though
Armenian
08-18-2010 10:14 PM
dhn0906
10-03-2009 05:28 PM
Simon0605
05-21-2009 04:35 PM
AntonyR
02-26-2009 04:50 AM
ballon78
06-25-2008 10:08 AM
Quick Reply: 90s over-heating, & replacing thermostat?
