'89 90Q turning rear caliper in
Old 12-05-2006 | 12:49 AM
bigant's Avatar
Default '89 90Q turning rear caliper in
Which way do I turn to get the caliper piston back in? I went to Advance auto and picked up one of those $10 tools but im having trouble with fitment to the piston. Anyone have any ideas?
Thanks,
Anthony '89 90Q 210K
Old 12-18-2006 | 12:25 AM
stingray944's Avatar
Default RE: '89 90Q turning rear caliper in
I'm not sure about your car but on my 1990 90 quattro both cylinders (driver and passenger) rear turn clockwise. How far out is the piston? I had to take mine off completely due to the piston out to its full range. Also if you open the bleeder it should be easier to turn back in. It would'nt hurt to take off the tension spring on the emergency break. If you take that spring off though watch that you don't move the lever it was attached to. It will move the piston back out and you will have that much more to put back in.
Old 12-19-2006 | 12:12 AM
InExile's Avatar
the tool should be a pretty good size hex key
audivalley
07-26-2012 01:19 PM
audivalley
07-24-2012 09:30 PM
mandito219
02-03-2009 08:09 PM
audi_kris
06-29-2007 05:59 PM
kakarot
05-04-2007 01:51 PM
Quick Reply: '89 90Q turning rear caliper in
