88 80 non-quat won't start cold
Old 04-10-2007, 04:16 AM
frankinstyn's Avatar
Default RE: 88 80 non-quat won't start cold
Looks like this...
Old 04-10-2007, 04:24 PM
nn2004's Avatar
Wouldnt leaky injectors foul the plugs?
Old 04-10-2007, 06:49 PM
Not necessarily. The engine would have sat for a while right? Perhaps a few hours...perhaps overnight. The injectors would leak out their residual pressue which would sit on top of the pistons inside the chamber. It would then slowly leak past the rings into the oil. later it would burn off as the engine heats up. You wouldn't see it on the plugs in that case.
However, that lost pressure would have to be built up again as you are turning the engine over which explains the longer starting times.
Frankie
Old 04-11-2007, 09:35 PM
nn2004's Avatar
Makes sense. The battery got a bit weak after so much cranking and so little driving. Took the battery out, charged it, and now it really doesn't want to start. I know the computer has to relearn, but I drove it around yesterday and it's still not working like it was. Acts like I'm not even pressing the accelerator for about 2 minutes. Sometimes it stalls. Oh the fun..
Old 04-12-2007, 02:59 AM
Interesting. I'm not positive here but I would say that has to do with the computer taking into account for the O2 sensor. A new O2 sensor won't fix anything though. Just sounds like the computer is a little wacky. wierd. All I can suggest here is to check that you didn't bump anything but with the battery in the back seat, how could you?
Old 04-12-2007, 10:51 PM
nn2004's Avatar
Actually, mine's up front. It's definitely runnin funny..
Old 04-13-2007, 10:50 PM
InExile's Avatar
doble check on the vacum leaks
oxy sensor will not do anything , it only starts messin' with the comuter after the engine is at temp
get it started ... drive around for a while ... park it ... after 30 mins to an hour remove the spark plugs and get a flshlight and look inside the cyl foe wetness .... if there is somthin' wet ... get new injectors
leaky injectors cause alot of problems ... hard start ... rough idle ... stalling ... misfire .... bogging
  #18
Old 04-15-2007, 02:33 AM
nn2004's Avatar
I think it was bad injectors, it would always smoke excess fuel after it finally did start. Anyhow, got frustrated and sold it. Wife didn't want to drive it anyways. Thanks anyways for everyone's help. Hopefully it'll help someone else in the future.
  #19
Old 04-19-2007, 05:08 PM
Phaedrus44's Avatar
I don't see the regulator bolted to the fuel distributor on my 84. Could it be the thing that's attached to the driver's side of the cylinder head?
  #20
Old 04-20-2007, 12:32 AM
You're going to have to tell me what model 1984 audi you have and then I'll post a picture of what you're looking for.
Quick Reply: 88 80 non-quat won't start cold
