5000 Ignition Switch
Anyone have any ideas on removing an ignition switch out of my 1987 audi 5000 CD, its something ive never seen before.
It is a much smaller version then the other common audi ones (big black one with very spaced out priongs, and usually a purple harness) the one i have has a white backing, and i cant see anything to remove it. On top there is a small hole, so i thought it was held in with a set screw, but no small allen keys would fit.
Any ideas?
Any ideas?
RE: 5000 Ignition Switch
i guess i could look it up in the Bently , but those things are bioches
ny ign swithc went (the last position for starting) so i just fitted a starter button and put a fuse in one of the wires
I replaced my switch and it was easier then I thought. It took me about 30 minutes! I was thinking 2 hours! Just read the bently and gives you everything you need to know. Picking out the stuff for the little set screw took the longest to do.
