1989 Audi 90... newbi Questions
Old 12-19-2006 | 02:10 PM
Frenchie's Avatar
Default RE: 1989 Audi 90... newbie Questions
2 more questions:
1: I get an error msg, the icon looks like a fountain. Does that mean I have low Gas
2: I cant seem to get the lock on the gas tank going. Is there a special trick to it... Once I unlock it, It just spins freely without coming off...
ARGH
Old 12-19-2006 | 03:14 PM
techbod's Avatar
1. is low windshield washer fluid
2. when its spins freely its locked assuming you have a key type cap if you do then the key stays in the cap and cant be removed until its back on and locked
Old 12-19-2006 | 03:29 PM
Frenchie's Avatar
Ive got the gas tank sorted out... But I am still having problems.... It just never stops with this car...
I change the battery with a brand new one. The car will wont start. It doesnt click, The engine starts reving but it doesnt catch. Could this be related to the Distributor rotor?.... What should I look at..
Old 12-19-2006 | 03:38 PM
techbod's Avatar
possibly the rotor button worn badly ( that's a carbon brush in the distributor housing ) also check the rotor arm for rusting as that's what wears the carbon brush away, keep in there mate you are making progress even if you don't think so
Old 12-19-2006 | 03:49 PM
Frenchie's Avatar
Is it possible that the ignition synco isnt right... I am going to put my winter coat on again and see if I can get it to work.. Ill let you know how it goes...
Old 12-19-2006 | 04:08 PM
techbod's Avatar
firing order
[IMG]local://upfiles/12092/F440EC6F1CEC48DEAA42C7BF10BCE73C.jpg[/IMG]
Old 12-19-2006 | 04:42 PM
Frenchie's Avatar
Cylinder 1 is the one facing the firewall?
How do I know where to start on the distribution cap.
  #18
Old 12-19-2006 | 05:04 PM
techbod's Avatar
cylinder 1 is at the front not the fire wall, the black dot in the circle is cylinder 1 on the distributor and is counted clockwise as the arrow says 1-2-4-5-3
  #19
Old 12-19-2006 | 05:09 PM
techbod's Avatar
[IMG]local://upfiles/12092/E5E8BC84C21B4AB193BDA88C90077F5E.jpg[/IMG]
  #20
Old 12-19-2006 | 06:17 PM
Frenchie's Avatar
The syncro was out of wack. This is what I have done. Using the same color as the diagram above.. Yet It still doesnt work...
Quick Reply: 1989 Audi 90... newbi Questions
