10V and 20V Question
Is the 10V and the 20V block the same or different? I ask this because i have a 89 200 with a blown engine and i really havent gotten around taken it apart yet and i have a 87 5000 cs engnie going into the 89 200. So if the head was good on the 89 and its a 20v would i be able to swap heads to the 87 block?
RE: 10V and 20V Question
Is the '89 a 20v? I've never heard of a 20v in a 200 that old. I thought that the earliest 200 20v was the '91 200 quattro. Is the 5000cs motor a turbo or NA, all 200's were turbo, but not all 5000cs's were turbo. If you plan on keeping the turbo, you need to make sure that the head and pistons you are using are from a turbo motor to keep the compression low enough and the sodium filled valves. The block should be the same between your 5000 and 200 motors, but check the water passage on the front left of the block and make sure that it matches up with the head.
I thought that all cs were turbo while the S was na and i think i read somewhere that they put the 20v in the 89 200 at least im positive they did in the wagon and pretty sure they did in the sedan but ya it doesnt matter anyways i went over to work on it today to find a sohc 10v so im out of luck now i just need to find a 20v
akitamike
06-09-2008 11:05 AM
SouthernAudi
10-14-2007 06:47 PM
