*Help* Car Won't Start
RE: *Help* Car Won't Start
you will have to check the voltage of the battery when you try to start
if it falls below 8V or 9V then you have bad battery, but if the voltage stays, then you have to check ether the starter it self, or the solenoin.
many times solenoid goes bad, rather that starter.
and most of the times, the contacts in the solenoid go bad.
There is a way to check, if its the solenoid or the starter. but on a V6 you will have to remove the starter from the car. couse it be a PITA to get to the terminals.
If you want I can write the procedure, its easy, and is not rocket science.
PS check the voltage at the battery, then check the voltage in the car after the battery. Cold be the cable, but LOW, VERY LOW posebility.
cranks but will not start
Hi guys,
I have a AUDI A6 2.6L 1994 V6,
A few days a go my car when trying to start didn't, then I gave it 15 mins and then tried then it started without an issue, after that one day when I tried to start it it didn't, so I gave it 15 mins and tried, no luck, therefore I removed the battery terminal and gave it 5 mins and tried it again, then it started, 2 days ago the same thing happened, I tried waiting the 15 mins, removed terminals, but no luck this time, then after a few hours of checking oil levels cable connections etc... I decided to get my battery fully charged, today it got the battery and fixed it up and fired the engine, it still cranks but no luck on starting, I am not a techy guy so basic info on if I can get this started please!!
BTW, all indicators are fine, no issues to be seen except for not starting
Vict0ar
04-03-2014 08:38 PM
kinnes042
S4
04-10-2013 06:29 PM
brit.mike13
10-17-2010 08:26 PM
