SD card in Audi Symphony
Old 09-22-2011 | 01:39 PM
mjt211's Avatar
Default SD card in Audi Symphony
I have 2009 A4 Premium + with Audi Symphony system.
I recently bought a SDHC card (16 GB) and tried putting some MP3 tracks on it. The MMI system says the card is "Unreadable". Has anyone else had this issue before?
Thanks in advance
Old 09-26-2011 | 12:20 AM
barobax's Avatar
What SD card model do you have exactly? I would:
1. Check to see if the card works in other devices (e.g. camera, laptop, tv, etc).
2. Check if other SD cards work in the car.
I personally have a 2012 A4 Prem+ (with B&O sound system) and I'm not having any problems with my Newegg.com - Transcend 32GB Secure Digital High-Capacity (SDHC) Flash Card Model TS32GSDHC6.
Hope this helps.
Old 10-06-2011 | 11:28 PM
tilhas's Avatar
You need to update your radio.
What software do you have?
Old 11-18-2013 | 12:32 AM
shanebroughton's Avatar
Necro bump! I came across this article from Google and just wanted to add:
Make sure you format your card as FAT or FAT32! NTFS and the Mac OS file system won't work in our radios!
Old 11-22-2013 | 10:43 AM
Gazzmonkey's Avatar
I've read in the A4 manual that the concert system can only read a maximum of 4GB, which makes perfect sense if it's a 32bit system.
But if yours is symphony then maybe it's 64bit which means your card should work, might need reformatted to a compatible file format as mentioned in the post above.
Regards
ppgoal
B8 Models
11-07-2014 12:47 PM
camynkids
B7 Models
04-14-2010 06:28 AM
AudiMe2009
07-22-2009 06:54 PM
Bobert
07-06-2006 09:29 AM
VB05
01-11-2006 02:31 AM
Quick Reply: SD card in Audi Symphony
