CoilPack/Spark Plug Question
Old 10-26-2015 | 12:36 PM
John Smart's Avatar
Question CoilPack/Spark Plug Question
Hello all,
This is my first post on here after creeping for quite a while. I drive a 2013 B8.5 Audi A4 APR Stage 1. Recently, I have been noticing some symptoms that seem to be consistent with a spark plug or coil pack issue. These are:
-Slightly louder idle and distinctive change in sound when accelerating
-Clicking when accelerating (only briefly)
-RPMs slipping and occasionally getting stuck briefly. (Is that a "misfire"?)
-General noticeable lack in performance and acceleration. Feels a little sluggish.
Questions:
1. Does this sound like a spark plug/ coil issue?
2. Do Audi's have both a coil pack and a spark plug? (Unclear from google)
3. Which one should I replace, if they have both?
Thanks in Advance Guys!
P.S: No CEL
Old 10-28-2015 | 02:07 PM
ppgoal's Avatar
Yes, your engine has a spark plug and a coilpack per cylinder. Generally a misfiring coil will eventually throw a CEL. You might try a code reader. I have seen CELs go on and then off when the symptom cleared -- they do not always stay lit. As far as the symptoms, taken together they do not sound like plugs or coilpacks. Just a guess here, but the noise and sluggishness sounds like a diverter valve issue, although I do not know if the 2.0T uses them or if the oem is weak. I replaced them on my A6 when it was chipped as a precaution.
Old 10-28-2015 | 05:38 PM
sheldon's Avatar
+1 on what ppgoal said
The safest thing to find out what is going on would be to check the codes with a VAG-COM. A generic OBD2 reader will probably not be able to find the codes you need as they could be stored internally and many devices do not talk on that level.
Pilipenko
11-28-2011 10:06 AM
ee99ee
10-12-2011 12:28 PM
Buttershxc
10-08-2010 03:26 PM
chinosA4quattro
08-30-2008 07:43 PM
fear_my_thoughts
10-28-2007 07:05 PM
Quick Reply: CoilPack/Spark Plug Question
