Can I fit larger tires on 2011 A4?
A4 is shoed with 245/40-ZR18s. I have a set of RS4 replica rims from my A6 that carried 235/45-R18s. I'd like to fit them with a set of Continental summer tires in a larger size to fill the wheel wells a little better. Does anyone know if 245/45-R18s, 255/40-R18s, or even 255/45-R18s would fit without rubbing??
PS - I tried a search without success.
Thanks for the info. Here are the specs on the RS4 replica rims that fit perfectly on the A6. It did take a different lug bolt than stock.
Diameter - 18";
Width - 8.5";
Offset - ET38
PCD - 5x112
Weight - 26.5lbs
Centerbore - 57.1mm
Lug Bolts - 14x1.5 27mm R13 Ball Seat
Diameter - 18";
Width - 8.5";
Offset - ET38
PCD - 5x112
Weight - 26.5lbs
Centerbore - 57.1mm
