audi a4 b8 manual transmission noise
Old 03-16-2015 | 08:00 AM
vandunga3's Avatar
Default audi a4 b8 manual transmission noise
Hi My audi a4 b8 having a weird clunking noise coming from underneath the car when changing gears ( doesnt matter the engine turns off or while driving ) Im a bit worrying about this. Can you guys let me know what is wrong with my car ? Thanks a lot
inside the car ( hard to hear from the video ) :
Outside :
Old 03-16-2015 | 09:02 AM
jagtoes's Avatar
How many miles are on the car. Do we assume it shifts OK and there are no gear noises. It sounds like a problem with the linkage . I would suspect it might be a bushing that is worn out and you are getting metal to metal contact causing the noise. You can either pull the shifter boot and look in from there or get the car on a lift and look from underneath as someone shifts it.
Old 03-16-2015 | 09:51 AM
vandunga3's Avatar
Hi. Thanks for the reply. The car is 94000kms and it shifts ok however it does shudder on take off ( only on first gear ). The noise i heard is coming from underneath the car. Thanks
Old 03-16-2015 | 05:09 PM
Audi Tek's Avatar
Tech Certified
I'd have to see the linkage in action on a lift to be sure of anything
nemohawk
B7 Models
10-30-2012 01:00 PM
oh_superb
10-30-2011 03:24 PM
Blissra
B8 Models
01-15-2011 12:00 PM
99turboaudi
06-17-2008 09:49 PM
AML 225
10-29-2005 09:46 PM
Quick Reply: audi a4 b8 manual transmission noise
