What to replace during the timing belt job.
Old 03-21-2012 | 03:13 PM
b7ghost's Avatar
ECS tuning as well as other sites have complete kits including kevlar belt, and even include coolant!!! or you can talk to an audi dealer the parts run around 300. i recommend getting someone to do it, or finding someone that has a lift you can use. your car has to be put in service mode, which means the front end has to come off, radiator and all...just easier to get to everything with a lift. Audi B7 A4 Quattro 2.0T > Engine > Timing > ES#1876845 Timing Belt Kit - Ultimate Plus - 06F198002B7
Old 03-21-2012 | 03:31 PM
shipo's Avatar
Our 1998 Audi A4 2.8 liter Quattro has a "Service Mode" which doesn't require the complete removal of the nose of the car. Simply pull the bumper, remove a few bolts, screw in the "Service Mode" pins, and slide the nose of the car, radiator and all, forward onto the pins. Using this method eliminates the need for a lift and the need for removing the nose completely from the car.
Do later model Audi's have this feature as well or did Audi do away with a good idea?
Old 03-21-2012 | 05:51 PM
b7ghost's Avatar
everything i have come across says the front end has to come off, mine did, i know the b6 has to come off. it kinda sucks but you have access to everything up front and it only takes about 30 min to get there.
Old 03-21-2012 | 06:09 PM
shipo's Avatar
You have to have access to everything up front in the B5 models as well, but there is just enough play in the A/C lines and such to literally slide the entire nose assembly forward six to eight inches without physically removing it from the car (assuming the service pins are in place, otherwise the entire assembly will fall on the ground).
Old 03-22-2012 | 09:28 AM
jagtoes's Avatar
I believe there is a youtube video on how to do this job. Look it up and you'll get an appreciation on what it takes to do this job. Looks like fun.
Old 03-22-2012 | 04:14 PM
b7ghost's Avatar
i finally got a reply from an audi tech i know, you can unbolt it and slide it forward on the b7, so i guess i did mine the hard way...oh well lesson learned, at least i got some cleaning done with it apart
Old 03-22-2012 | 05:12 PM
shipo's Avatar
Cool, that's good to know; thanks for the follow-up.
  #18
Old 03-23-2012 | 10:40 AM
Ericcg82's Avatar
Originally Posted by rhodes991
I have some mechanical knowledge and think I may tackle this myself (with help), but what are relay rollers? That is a new term to me.
Relay rollers/damper rollers are just 2 rollers (different sizes) that are located on the block and the timing belt runs along them..DO NOT keep the old ones, the bearings will go before your next timing belt change and could lead to bad news..
  #19
Old 03-23-2012 | 01:32 PM
rhodes991's Avatar
Thought that was what they were, but wanted to confirm. Thanks.
zzskyy
03-04-2013 03:17 PM
Old_Beater_A4
09-28-2011 07:23 PM
TopSpeedCustoms
03-14-2008 08:23 PM
nismogt1
03-24-2006 11:06 PM
Dr Pooface
05-30-2005 02:21 AM
