Well, I guess I jinxed it!
I haven't pulled the DV off to verify, but it appears I might have failed DV. I threw a P0299 turbo underboost code this morning and after clearing it, it came back as soon as I got on the gas hard. I ordered the "D" revision replacement from ECS (thanks, 2wdBlazer for the part number and info in the sticky), so I guess I'm limping along with a 2.0 instead of a 2.0T for a few days until I get the part and have time to put it on.
Hope that's the problem--if it's something else, that'll kind of suck!
Sure enough, the DV had a 1cm tear in the diaphragm. DV is fixed, but I put off the PCV swap for now. Got my turbo back! I'm glad that was all it was. I also reprogrammed the quick-fix stuff you can do with a generic (non CAN-BUS) cable (seatbelt chime, amber corner delete, 1-click unlock, and key fob up/down). Soon, I will tackle that PCV...
