Vibration at low speed, abs and esp light after replacing axles
Hi,
I have a 2007 audi a4 2.0T fwd auto with the cvt and I just replaced my passenger side axle today and when I went for a test drive there was a pretty serious vibration and low speeds, plus the abs and esp light came on. Any ideas?
This is the first time I have replaced the axles. I bought new axles, but i'm not sure what you mean buy if I bought them from the dealer or from and aftermarket company that are meant as factory replacements, but I bought new aftermarket from carquest $86 apiece I think. Torque wrench only went up to 100lbs so I did that then went a little farther with a breaker bar. Brakes work great, I don't think I did anything to effect the alignment, I did have to un bolt the pinch bolts from the knuckle(?) on the passenger side but not the driver side. I have reason to believe this has something to do with the passenger side, because I did that side, then drove it and that's when the problems came up, so I replaced the left to see if that was it and it didn't fix it
I think the reason I did the second one was because there was a serious vibration before replacing either of the axles so I thought (and now realize I was wrong) that it was from the driver side axle still being bad.
Would it be smarter to rebuild the oem ones I pulled off or return the ones I bought and get some from audi?
That said, how's your tire wear? wearing evenly? No cupping issues? Have you checked suspension and steering components under the front? Is the vibration in the steering wheel, seats, whole car? Does it do it at certain speeds?
MattP87
03-22-2010 09:25 AM
