Turbo Lag
Old 06-30-2008, 11:13 PM
atomic191's Avatar
Default Turbo Lag
Hey guys and gals. Just purchased 08' A4 2.0T. Love the car. It could use alittle more hp. I've looked into chips and exhaust. probably going with GIAC chip, Borla exhaust. Been reading the forums and it seems that all the upgrades is going to make the turbo lag even worse. (Only thing I don't like about the car: TURBO LAG) any ideas on how to solve that problem?
Old 07-01-2008, 01:35 PM
harryd14's Avatar
Default RE: Turbo Lag
there is one product that a thread was talking about which basically allows more power available to your use at a lower point in the rpm scale. What it does basically is trick your computer into thinking that the throttle bodies are more open that they actually are so they recieve more of the power than they are normally given. this especially helps with hill starts and what not. it costs about $300 and one guy who bought it said it really helped improve initial power... now let me see if i can find that thread.
Old 07-01-2008, 01:38 PM
harryd14's Avatar
ok well i was slightly mistaken and this thread wasn't about turbo lag but may still be interesting to you i dunno... you can take it or leave it. but the only real way to avoid turbo lag is to get a variable ratio turbo
https://www.audiforums.com/m_901255/tm.htm
Old 07-01-2008, 07:45 PM
dmfan016's Avatar
you can try a supercharger
from what i hear theres no lag at all haha
Old 07-02-2008, 01:39 PM
bem1's Avatar
Personally, I have not experienced any Turbo Lag in my 08 A4 2.0T. And I know all about Turbo Lag, as I drove a 1998 Eclipse GS-T for ~9 years...
-Blake
Old 07-02-2008, 05:24 PM
dmfan016's Avatar
there shouldn;t be too much turbo lag if your car can breathe properly, turbos as small as the ones that are in the 2.0 are far too small to have a significant amount of turbo lag, an exuast and air filter and possibly the throttle response chip are all likely culprits
Old 07-03-2008, 04:01 AM
vtracer20's Avatar
my old 1.8t with turbo inlet pipe and full exhaust had quicker turbo spool than when with stock. cant say the same with my 2.0t cause i havn't purchased those aftermarket parts. If your not happy with turbo lag then buy a different car, you just have to get use to it, change your driving style or something, having a turbo is much different than a NA car
Old 07-03-2008, 01:27 PM
fellinlovewb7's Avatar
The apr chip seemed to improve the hesitancy off the line, however the turbo still does not kick in right away, but the increase in HP makes it less noticeable, get the chip before proceeding with other mods as numerous posts have noted.
Also I heard the GIAC chip puts more strain on the engine than others but it also increases the performance a bit more, I have read this and the mechanic at 2bennet audimotive mentioned the same... however there are numerous others who have had no problem or issues with it
Old 07-04-2008, 08:35 AM
vtracer20's Avatar
i went through a turbo on my giac chip on my 1.8t.....no issues getting a new one (under warranty)
Old 07-04-2008, 08:42 AM
audiprotein's Avatar
Well basically the earlier turbo spools, less turbo lag you get.
Lets say on 1.8T u gotta wait till 3k rpms for the full boost, i guess the same thing is on 2.0T.
Quick Reply: Turbo Lag
