TPMS Problems, Error code 01833
Hi All
This is my first post here, so bare with me. I got the follwing error code from VCDS, and i was just wondering, if i need to replace the antenna located at the rear bumber. I tried disconnecting the antenna, but the error code is still the same. If you need to full fault code scan please let me now.
I really hope someone have some input or things i can try in order to find the root cause of this problem. (And all 4 tires do have sensors) :-)
Thanks
Thanks
Code:
Chassis Type: 8E - Audi A4 B6/B7 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 8E0-907-273.lbl Part No SW: 8E0 907 273 A HW: 8E0 907 273 A Component: Reifendruck 3 H04 0130 Coding: 0022222 Shop #: WSC 06435 000 00000 VCID: 2A511C7186E4089 2 Faults Found: 01521 - Sensor for Tire Pressure 002 - Lower Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 40 Time Indication: 0 Freeze Frame: (no units): 0.0 Voltage: 11.70 V (no units): 19.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01833 - Antenna for Tire Pressure Monitoring; Rear (R96) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 Freeze Frame: (no units): 0.0 Voltage: 11.70 V (no units): 130.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn.
I have thought about that as well. I was just wondering if anyone could give any hints to what exactly was wrong, however I did some research and based on that, I believe that the sensors in the tires just ran out of battery power, while in storage over the winter.
I suppose that this is the procedure for disabling TPMS:
Code:
Select -> 17-Instruments -> Adaptation -> Channel 61. Subtract 512 from whatever value you find there.
