P0171, P0507
Old 05-23-2008 | 01:34 PM
drigolia's Avatar
Default P0171, P0507
Hi, I have a 2005 Audi A4 2.0T
I downloaded these codes using an OBDII
P0171 System Too Lean (Bank 1)
P0507 Idle Control System RPM High
Any idea what the fix might be?
Thanks all.
Old 05-27-2008 | 08:24 PM
drigolia's Avatar
Default RE: P0171, P0507
well whatever they are, I went ahead and deleted them (turning off the check engine light). I want to force the light on again and download the codes to be sure they are the right ones.
Old 05-29-2008 | 06:38 PM
dmfan016's Avatar
perhaps clogged injectors?
Old 06-01-2008 | 04:57 PM
drigolia's Avatar
after driving about a week, the light finally came back on. i read in a few posts thatP0171 might be the MAF sensor. the reason i created a new post was because i also had the P0507. they recommended i clean the MAF sensorbefore replacing it so i did thatand cleaned out the air filter. i returned the scanner so i had to clear the light by disconnecting the battery.
does anyone think the 507 might be caused by the 171?
Old 06-03-2008 | 09:40 PM
drigolia's Avatar
umm?
Old 06-04-2008 | 03:07 AM
ocadam's Avatar
clean your MAF and reset the codes. if you keep on comig into problems private message either Techbod or auditech79
akm0228
07-07-2014 01:50 AM
jerrylimang
05-23-2014 07:44 PM
hebert12lax1
12-01-2013 05:37 PM
drigolia
10-22-2009 06:15 PM
projlightning
04-24-2007 01:22 PM
