Overheating problems
Need help
History of car it had a new head a couple of months ago
Also looking at service history it also had new water pump
Purchased car 12 weeks ago
Last week the coolant alarm came up on dash checked water level and it was fine
Top hose boiling hot bottom hose cold, to it to local mechanic and he took it apart checked water pump and thermostat all fine
Filled it back up with water and anti freeze problem still there so really not sure
Also don't know if this is linked but won't start on key on cold start takes ages and runs rough Untill warm then the temp gauge goes from 90 to 130 and back like a yoyo with the coolant alarm going
Can any one help please
From your description I would have thought water pump or thermostat. When the mech took it apart did they replace those parts again? The only other item I can think of is a blocked water passage in the block, one of the hoses, or the radiator. Are you lossing coolent as well? Any smoke out of the tail pipe? Does the oil look foamy?
