just got a A4 2.0T 100k timeing belt waterpump replacement?
Old 04-03-2012, 09:14 AM
nmdjr's Avatar
Default just got a A4 2.0T 100k timeing belt waterpump replacement?
Just got a used A4 2.0T. It was frm a private owner no clue about car grandparents. I looked over car super clean engine great. But how can I tell if the timebelt been replaced? Any help would be great to help gas and performance. Thanks in advance.
Old 04-03-2012, 10:50 AM
rhodes991's Avatar
If they didn't know I would probably take it to a mechanic to see if they can tell. Otherwise plan on changing it. I would rather spend a grand replacing the belt than having it fail and take the engine out in the process. Someone else on here might be able to give insight into what to look at for clues if it was replaced.
Old 04-03-2012, 12:10 PM
shipo's Avatar
I don't suppose the previous owners still have the service records; might be worth your time to ask.
Old 04-03-2012, 06:51 PM
M5S5's Avatar
Tech Certified
I agree , try & do a little research see if you can locate service records. Do you have a way of contacting the previous owners?
It's kind of hard by looking.
Old 04-04-2012, 07:51 AM
Sarge786's Avatar
Also worth having a word with your local Audi Dealer, if it has been done 'any' Audi Dealer, then they will have records of it been done, and can tell in seconds from their computer screens.
If you find that Dealer doesn't have a record of it being changed, and there is no record of any other garage changing it, then get it done immediately, visual inspection doesn't mean anything usually and cannot tell any useful info from just looking at it.
Old 04-04-2012, 09:15 AM
KingWulfgar's Avatar
I agree. This is one of those things that spending the $1000 now (or possibly a bit more) will save you multiple thousands later when the belt breaks and takes your engine internals with it.
Old 04-04-2012, 09:16 AM
shipo's Avatar
Fortunately a DIY job will cost considerably less than $1,000; if the OP is so inclined.
Old 04-04-2012, 09:21 AM
True. That's definitely one job I would never even consider doing myself, though.
Old 04-05-2012, 03:31 AM
nmdjr's Avatar
Wow. Great info and advice. Thanks all. I have taken your advice and info and am planning to bring to a dealer. 1300.00 is a good investment. I didn't look at the arfax shows at 105000.00 brought to dealer no specifics on work ill give a call. All in all going to change it. Wish I had the manuel. Thanks again. Safe. Driveing
Old 04-05-2012, 06:33 AM
shipo's Avatar
Why not? Compared to the tedious but doable 2.8 and 3.0 V6, the 2.0T is sure to be far easier to do the timing belt on and certainly doable for the average back-yard mechanic.
Quick Reply: just got a A4 2.0T 100k timeing belt waterpump replacement?
