Interior lights
Interior lights
hello I'm trying to replace the interior lights on my 2005.5 a4 and needed some help wit the bulb sizes/types. I want the replace the four maplights in the front and two overhead ones in the back. I know two in the front are the festoon. I'm buying the LEDs from superbrightleds.com. Any feedback is appreciated.
if you buy LEDs make sure you buy resistors as well because i believe the lights in the a4 are standard bulb lights and not LEDs so if you make the switch....which is totally possible you just need a resistor for every "set" or circuit of LEDs you are running because they operate differently from a standard bulb
There's a bulb size/type guide here at Sylvania's website: http://www.sylvania.com/ConsumerProd...lacementGuide/
Angfang, let me know how changing the bulbs goes and if you could post some pics that would be great because i have also been wanting to change my interior bulbs too... have you thought about replacing the 2 red lights that shine down on the center console to brighter red leds?
well im trying to do something similar to this..
http://users.adelphia.net/~ashleighk14/A4/leds.htm
but the guide doesnt mention about the bulb size/type except for the one under seats (which i dont plan on doing).. and the sylvania number for the map light doesnt cross reference wit the led map light.. idk i have to do some more research but im still checking here for more advice..
yeah ill have to try that as well, but i dont know if i want only red leds otherwise if im trying to read directions or something i wont be able to see very well, or are those just the lights that come on when you open the doors?
Emac, the url you tried to post didnt work, could you try again?
Hmm, not sure what happened to it... it seemed fine when I posted
Anyway, here are BA9S LED's: http://www.superbrightleds.com/cgi-b...gi?product=755
And here's a reference for 64111 corresponding to BA9S: http://www.replacementlightbulbs.com/lamp64111.html
Hey, I actually found that same page on that adelphia thing, and want to do the same thing to my 2003 A4.
I found two lists, one on that sylvania site, and another elsewhere ( http://www.modifiedlife.com/2003-aud...-size-diagram/ ), and the list goes:
Glove Box Light Bulb Size: 2825
Map Light Bulb Size: 64111
Dome Light Bulb Size: 6411
Step/Courtesy Light Bulb Size: 2825
Trunk/Cargo Area Light Bulb Size: 6418
Under Hood Light Bulb Size: 6411
Does anyone happen to know how *many* I should order and what the conversions are to LED bulbs? I'd really like to get some with internal resistors, if possible.
The closest I can think is:
Glove Box Light Bulb Size: 2825 (1?)
Map Light Bulb Size: 64111 (4?)
Dome Light Bulb Size: 6411 (2?)
Step/Courtesy Light Bulb Size: 2825 (8??)
Trunk/Cargo Area Light Bulb Size: 6418 (2, lower back and upper top?)
Under Hood Light Bulb Size: 6411 (I don't even know where this bulb is located, though it would be nice to have)
So really I need (guessing here) 9x2825, 4x64111, 2x6411 converted to LED light bulbs. Off to google I go, any help here is appreciated though!
