i need help rear sunroof drain leaks !!!!
hey guys i am new in here
i need help with rear sunroof drain hose. it is leak
i noticed a couple of days ago after car wash that both rear headliner corner
get wet. i am not sure it disconnected or clogged but i think it is
disconnected or damaged somehow. Water drains fine both side, i tested
myself
please give me an advice or DIY for rear drain hose replacement.
myself
Both my 2000 Jetta GLX and my 2006 Audi A4 got the service bulletin. Debris can build up and clog the drainage system. I actually periodically take my shop vac with the micro attachments and try to suck out the crud built up in drain tubes with it. But then, I don't open mine very much so there isn't much opportunity for stuff to build up in the drainage channels.
