How often do you guys change the oil filter?
I am just curious how often the owners of a 2008 Audi 2.0T change their oil filter?
And how long does it take for the tiers sensor sign to go away after putting some air in the tiers and the spare one too.
Oil filter should be done with every oil change, especially on a turbo motor. Failing to do so will cause a sludge build up that will be a huge headache. Filters are cheap and easy, save yourself the headache and don't cut that corner.
As for the tpms, it should register instantly. If it hasn't, you might have a bad sensor.
tire pressure do not register instantly or automatically..... you have to store them after setting the pressure by pressing the button on the side of the wiper stalk and scrolling thru the menu in the DID display
^this. Especially on the 2.0t. This motor eats oil about 1 quart every 1500-2000 miles because it feeds the bearings on the turbo and thus a lot of oil gets into the intake piping/manifold. Top it off asap, not having enough in there not only risks damage to the motor, but could also seize the turbo and that would not be fun for you. If you can't get it topped off for a couple days, don't drive it. If you absolutely cannot avoid driving it, don't drive hard, and don't drive far. 5 miles granny shifting and staying out of boost should be tolerable. More than that you're playing with fire.
