Cam Follower
Cam Follower
Hi everyone,
My 2006 A4 2.0T FSI have 80k miles and I am planning to do some work on it. I need to know the steps to take out the valve cover and change the cam follower. If anyone knows what else might be checked or changed I would really apreciate your feedback. Any suggestion is welcome. Thanks in advance.
Bandmax -- Good luck on this! I nearly did this myself, but ended up not doing it for other reasons (thank goodness as my post yesterday will explain).
From all the research I did, make sure that you buy all new seals for the HPFP before jumping into it. The best directions I found were here:
http://freepdfhosting.com/8791e81dac.pdf
Good luck!
Good luck!
Thanks Joe,
This is what I was looking for. I really don't want to damage anything else than what may be already damaged. I asume that the car may need a little work. I just pray not to have the pump damaged or the cam. I will post here updates of my findings.
