brake light bulb?
There is a video on this this forum or Audiworld's forum. It's actually a B6 body, but its the same concept. There are 2 little round disks in the trunk liner on the sides of the car. One on each side near the very back. You can stick a special tool in it and turn it, or some even say a flat blade screwdriver. I forget how much you turn it, but eventually it lets the light unit pop out of the back of the car.
Thanks a bunch... I found what you described... Inserted a small flat-blade screwdriver loosened it and the bulb replace emnt was a snap. I was fearing that I'd have to remove all of the side trunk moulding, but you made my task an easy fix... Thanks again
MagicHobo
11-14-2008 01:37 AM
